Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Xterra Projects
Thread Tools Display Modes
  #1
Old 11-27-2009, 02:30 PM
Oz's Avatar
Oz Oz is offline
Moderator
the Tallest IFS Xterra
Default Boxing Your Arms - Progress 12-23-09; Passenger side done!
So - I have a little down time waiting for my Titan Dif to return. I want to install my Titan Upper and lowers at the same time so while my LCAs have been laying around I've decided to strengthen them a bit like Oregon did. But I went a little farther and decided to Box them.
Here's what I started with - an OEM Titan Lower (Bottom view)
OH and in the bottom of the photo you can see the material I'm using. 3/16" Channel and 1/8" plate
Top view
I started by shaving off the sway bar mounts
OK- Everyone at the shop went home for thanksgiving so i couldnt take any more pictures up to this point. But all i did was make a cardboard template for the top, drew that onto the plate and welded it up.
Front side: I cut a length of the 2" channel,I think it was 17". I cut the ends at the same angle to match the LCA. Then I tacked on and welded.
NOTE; Seriously, I am not a welder. In fact this is the very first thing I ever welded. My first weld are on this piece. SO YES That looks like a LOT of grinding has occurred Anyway im hoping my welding will improve.
Here's the bottom
AND because its the eve of Thanksgiving I can't finish this today - but here are some photoshop comps of what itll look like finished. Hopefully.
Bottom
Stay tuned!
PROGRESS 12-23-09; Pass side done!!!
These are coming out as I wanted. Just a little more grinding and then prep for paint. Have to finish the Driver side next which should go quicker and now I've learned some shortcuts.
OH, and I weighed them. 15 lbs. stock - 30 lbs. boxed.
  #2
Old 11-27-2009, 02:39 PM
chrishaynesusa's Avatar
chrishaynesusa chrishaynesusa is offline
Master of the Obvious
2005 Xterra S
Default
My Girlfriend cant dance, but you ought to see her box
__________________
Member # 25
"Roads? Where we're going we don't need roads." - Dr. Emmett L. Brown
My Silver X
  #3
Old 11-27-2009, 03:01 PM
Oz's Avatar
Oz Oz is offline
Moderator
Default
Quote:
Picts ?
  #4
Old 11-27-2009, 04:13 PM
SeXterraPA's Avatar
SeXterraPA SeXterraPA is offline
Regional Moderator
2005 Xterra S
Send a message via AIM to SeXterraPA Send a message via Yahoo to SeXterraPA
Default
Oh, good stuff so far Oz. Me likes what I sees.
__________________
Stephen Q. Breslin - The Beast from the East
'05 - Super Black "S" 4x4 - 6MT
GPAX Founder/President - NeXTerra Sponsorship Coordinator
  #5
Old 11-27-2009, 04:16 PM
OregonX's Avatar
OregonX OregonX is offline
Regional Moderator
Default
That's cool, Oz. I take it Greg talked you out of the Titan mid-travel setup?
__________________
www.evilikesoffroad.com
  #6
Old 11-27-2009, 04:28 PM
Oz's Avatar
Oz Oz is offline
Moderator
Default
Quote:
I still want to do the mid travel arms - but probably next year. Work has been slow, my commisions are down 20%, saving for a house etc etc. So its just a matter of not shelling out big cash for mods right now.
  #7
Old 11-27-2009, 04:48 PM
Wanderlust's Avatar
Wanderlust Wanderlust is offline
2006 Xterra Off-Road
Default
Looks good....
__________________
Umm, I have an Xterra....and now an Avatar.
My Ride
Photo Gallery
Hawaii Xterras
  #8
Old 11-27-2009, 05:12 PM
mcampana's Avatar
mcampana mcampana is offline
Send a message via AIM to mcampana
Default
So this is for added strength correct OZ? Looks good either way.
  #9
Old 11-27-2009, 05:26 PM
Oz's Avatar
Oz Oz is offline
Moderator
Default
Strengh - probably overkill but it'll be a nice skid. To me, LCAs are obviously in a pretty vulnerable location
  #10
Old 11-27-2009, 06:02 PM
mcampana's Avatar
Default
I hear ya, id rather go overkill with that stuff.
You may not post new threads
You may not post replies
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org
