  #1
Old 11-07-2009, 04:45 PM
Oz's Avatar
Oz Oz is online now
Moderator
the Tallest IFS Xterra
Default OBA On The Cheap
OBA (On Board Air); I've wanted to do this for a while. First I picked up this portable compressor about 2 years ago. Tsunami; a really cheap one from The Boys at Pep for less than $50 bucks. Not the greatest by any means but works like a champ:
First carefully remove the front plastic grill by carefully removing the (4) plastic clips:
Inside I found a really great mounting spot. There's a structural plate on the inside of a SWs bumper. You can kind of see it here: (arrow is pointing to it)
Here's another view of the mounting location:
I drilling 4 holes that lined up with the base plate holes of the Tsunami. You'll have to remove the rubber feet that were inside those holes. Put the compressor in there and mark the holes for drilling. Make sure the compressor in not too close to any wires or hoses that could cause future probs by any rubbing. Remove the compressor then drill your holes.
Next tap the hole that feeds the air line. Tap it for a 1/4" brass air nipple (Note: the threads measure like 5/8"). You'll have to remove the quick disconnect fitting first obviously that came with the compressor (its the cheap, chrome crappy one). Yellow arrow in the picture shows which hole it is. (forgive the 'already installed' photos - I did take step-by-step photos while i was during this but my flash card failed and I had to do these after the fact)
After tapping that hole install the compressor with your favorite fastener.
In this picture purchase these (3) items: (1), a 1/4" brass nipple, (2) a 1/4" brass elbow, and (3) some kind of airline that will have 1/4" brass fitting on both ends. I opted for a teflon stainless steel braided line. Mine was 17" long and cost $26 (you dont have to go for this expensive of an option - you could use a piece of an old airline with 1/4" barbed ends and hoseclamps. I always like to use teflon tape when doing any kind of fitting like these.
Here's what it looks like so far:
On the other end I put a quick disconnect in case I need to dismount the bumper I can disconnect the airline easily.
Using a washer and a 1/4" brass coupler I mounted a quick disconnect male fitting here:
On the back side of this is another quick disconnect male fitting, this is where the stainless hose connects to.
Inside view installed:
After that you can just wire the compressor directly to the battery. The Tsunami has an inline fuse in the power wire. Switching it on/off is easily done by reaching into the square access holes in the SWs bumper.
Here's what it looks like in operation:
That should be it! Now say goodbye to the crappy storage bag and the one dimensional airline:
  #2
Old 11-07-2009, 04:51 PM
SAMI's Avatar
SAMI SAMI is offline
2006 Xterra S
Default
Nicely done. I miss OBA.. Maybe I'll add that for '10..
Do you have a plastic cover for the output on the bumper?
  #3
Old 11-07-2009, 04:55 PM
Oz's Avatar
Oz Oz is online now
Moderator
Default
Heh, I did ! I was using a plastic/rubber thread protector that came inside the quick disconnect. Fit perfectly. But I turned the compressor on forgetting to take it off and it shot out like a bullet - cant find it. I'll have to swipe another one from Harbor Freight
  #4
Old 11-07-2009, 04:59 PM
Tress's Avatar
Tress Tress is offline
Supporting Member
2009 Xterra S 4x4
Default
Very nice write up and install. My only suggestion would've been to drill the hole for the air fitting inside the bars on the bumper to protect it a bit from snapping off if you hit something.
__________________
AJ Sliders | Dephep Roof Rack | Shrock rear bumper |
265/75/16 BFG AT KOs | Kenwood DDX712 | Raingler MCN net |
GOBI ladder | Radflo 2.0s | Deaver AAL | Bilstein 5125s
  #5
Old 11-07-2009, 05:02 PM
LA RANA's Avatar
LA RANA LA RANA is offline
2005 Xterra Off Road
Default
nice Oz!
__________________
LA RANA
Tread Lightly, United Four Wheel Drive Association, Virginia Four Wheel Drive Association, TheNewX, NOAS, NORA, NOR, VA4X4, VAXC, GPAX, CX, CF, TT, Big Dogs Offroad
  #6
Old 11-07-2009, 06:00 PM
Muzikman Muzikman is online now
Administrator
2005 Xterra Off-Road
Send a message via AIM to Muzikman
Default
are you worried about getting moisture in the intake?
  #7
Old 11-07-2009, 06:09 PM
Oz's Avatar
Oz Oz is online now
Moderator
Default
Quote:
no but if there was ever an issue I was going to plumb the intake with a hose over to the airbox. Should be easy enough
  #8
dezurtrat's Avatar
dezurtrat dezurtrat is offline
Supporting Member
2008 Xterra OR
Send a message via AIM to dezurtrat Send a message via MSN to dezurtrat Send a message via Yahoo to dezurtrat
Default
Very creative. Nice work.
  #9
Old 11-07-2009, 06:27 PM
IZVERG's Avatar
IZVERG IZVERG is offline
-Gimp Moderator-
2005 Xterra S
Send a message via AIM to IZVERG Send a message via Yahoo to IZVERG
Default
Nice ingenuity, Oz-Man!
  #10
Old 11-07-2009, 06:40 PM
jeff_redx's Avatar
jeff_redx jeff_redx is online now
Supporting Member
2009 Xterra Off Road
Default
Does the compressor motor need to be kept dry or is it water sealed? Nice installation, it certainly makes it easier to use.
Jeff
__________________
Life is not measured by the number breaths we take but by the moments that take our breath away.
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Gear & Equipment
You may not post new threads
You may not post replies
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org
